Old 03-31-2013, 02:05 PM   #22
thom4782
thom4782's Avatar
If you have coolant outside of the tank, then you have a leak. It just that simple and the cause is either a broken tank, cap or connecting hose. Eventually, you will lose enough coolant that your engine will overheat. If it does overheat, you may face thousands of dollars in resulting engine damage.
