I plan to replace the whole pump assembly.
The remainder of the bolt is 1.5cm long, hopefully I can find the rest in the sump/filter. Its too small to be a load bearing bolt, similar to a sump bolt etc but without stripping the engine, not much hope.
I am planning to fit a magnetic sump plug too so any debris may be picked up here. I still have the drained out to filter too - can't wait!
It will all end in tears I tell you.......
