Old 03-29-2013, 03:28 AM   #12
Skootnasty
Originally Posted by runjmc2 View Post
It's a moot point. As we now know, if you have a double row it will never go bad anyway. If it is a single it's a timebomb and you are covered. End sarcasm
Not breaking apart, and not being bad are not the same things. The dual row bearing still suffer from rubber seal failure which displaces the sealed grease. With twice as many balls there is twice as much ferous metal debris that can/will conaminate other bearing surfaces (namely cam and crank surfaces).
The improved durability against breakage/toal failure is a compromise to more metal contamination circulating through the lubrication system.
If you have an engine with a servicable bearing its worth changing as early as possible. IMO
Skoot
Skootnasty is offline   Reply With Quote
