Old 03-27-2013, 02:18 PM   #1
Autobahn Pete
Considering the oil is pooling on top of the cylinder head/engine block seam and next to the oil cooler. I would check the oil cooler seals first.
If it were P/S fluid, it would be a "greenish" color, P/S fluid is Pentosin CHF11S. Check the level in the P/S reservoir, if it's not very low, then it's probably not the P/S considering looking at the amount of fluid in your pictures that the car is leaking.
If the oil color is dark brown, it's more than likely engine oil.
Autobahn Pete is offline   Reply With Quote
