Thanks! If you can re-post teh pictures I'm sure they would help. I'm not following the description,
" had to drill out the front lower corner bracket a small amount and I had to remove the original factory end from the cable housing. All of this was easily doable while installed in the door. This what the final fix looks like:"
Is the bracket and cable housing on the motor? Any additional description would be helpful, but now I know that there is a fix by taking slack out of the cable, and improving the design in the bargain! Thanks for the information.
Jim
