Thread: Window Woes
Old 03-23-2013, 06:58 PM   #1
Jamesp
Beginner
Jamesp's Avatar
Window Woes
Perhaps someone has seen a Boxster window do this before. When the door handle is lifted to open the door, the window motor runs to lower the window, but the window does not lower. You can then coax it down with your hand to open the door. Replacing the window regulator seems like a correct fix, but before going off half cocked and doing that I thought I'd see if someone on the Forum had experiance with this or a better ideahttp://www.986forum.com/forums/images/smilies/nopity.gif
Jim
