Car is $9K because it's green! And a weird green at that.
Move on. You'll get bored with that color quickly. As a test run, go out and buy a pair of neon green shoes and wear them every day for a month.
Also, not many options on that car. Old school Edison bulbs on the headlights will cost you $2K or more to update to the Litrnoics. The top replacement for glass will ~$1500. You're getting close to new shock time, since I see there's snow in the background this isn't a SoCal car that goes easy on the suspension. For a couple of grand more you can get a 3.2. And don't forget to add $2K for a clutch/IMS/RMS job for a 2001-2005 Boxster. Some roll the dice and skip this others decide they like not to having catastrophic engine failure in the back of their minds anymore. And this car has some very well known weak spots like the waterpump, coolant tank crackin, AOS and other possible unexpected repairs that have not been addressed. A car that has only had oil changes driven year round in a four season address is not a car I would be considering. There is no such thing as a $9K Porsche. My car driven only weekends and largely garage kept required over $10K maintenance and repairs well before it hit 100K miles, its still under 90K as a matter of fact. Meanwhile there are cars from L.A. that have barely had one repair. Know the history of the car.
Also, If you're someone with an eye toward replacing the engine at some point you might want 2002 and newer, if I'm not mistaken, most of the Carrera engines can be swapped in.
BORN: March 2000 - FINLAND
