Old 03-21-2013, 10:40 AM   #2
cameronzero
IMHO, have your suspension properly set up. unless you're obscenely low (coilovers max'd out like a tool), the factory alignment bolts should be able to correct the issue, or you could buy the factory suspension and not have to worry about it at all as these cars are usually 4" from the ground to begin with.
i purchased my 986 used and it has "lowering" springs all around but it still aligns correctly as they aren't worn out, is properly aligned, and running factory wheels.
cameronzero is offline   Reply With Quote
