Old 03-20-2013, 06:21 PM   #10
KRAM36
Need For Speed
KRAM36's Avatar
I had this same issue a few weeks back. Exactly as you mine happened when heading home from work and a big snow hit. I thought it was the water pump, so I ordered a new one and a low temp stat. In the end I didn't need either, I needed to add coolant and bleed the system with the coolant bleeding valve. I had added coolant, but it kept over heating, being a new Box owner I didn't know about the bleeding until I already had the parts and was reading up on how to replace them and read the bleeding part. So I have $300 in water pump and low temp stat sitting here doing nothing lol. I'll probably replace them when it gets warmer out. Where the heck is Spring?
