You can fix it with some epoxy if your clever. Open it up and you'll find a little sliver that holds it together. Otherwise, DO NOT LOOSE THE pill, keep the "sword'. Get a key from ebay and swap the parts.
Note: You can start the car by holding the broken fob or just the pill next to ignition switch and inserting the "sword" and twisting with pliers. once' running, it won't stop, key fob/pill or not.
Regards, pk
