Old 03-17-2013, 03:00 PM   #7
pk2
The trick is the hidden torx head screws. On the left is a fake little microphone cap, on the right is a the emergency flasher switch. Pop them both out and you'll find the torx head screws. Remove them. The whole pod comes out. you'll be styling
From there, disassemble as needed....no brainer Oh ya, there are three color-coded plugs, tricky latches but you can not mix them up.
"assembly is reverse"
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
