Old 03-16-2013, 10:40 AM   #14
sam c.
Thats an excellent "milling machine" to destroy your crankcase when the bearing fails.
When it fails, the impellers hit the engine case. If the impellers are metal, they will chew through the case and ruin the motor.
Note: WHEN it fails...! Not "if" and regardless if you maintain your car, but WHEN it fails, you're done.
Originally Posted by Spinnaker View Post
the plastic impellers break even when the bearings are still fine
Originally Posted by shadrach74 View Post
I've been stranded twice by plastic WP impellers that split in half. I've had only one metal pump fail, which amounted to a minor leak
Which was then followed by this classy retort...
The person who made those statements has obviously never touched an M96 engine. Typical.
We have had three cars in the shop that had the engine cases ruined by metal impellers on aftermarket pumps that had to have replacement engines. In addition, we have had others where the engine cases were torn up
Wow. So the take away from all this is you can't use a metal impeller because it will almost immediately come alive, devourer your block, and when it's done come after you and your family.
So in summary, water pump with metal impeller = :troll:
And you can't use a pump with a plastic impeller because you won't get around the block without it shredding into plastic confetti requiring a complete tear down of the entire engine for cleaning.
water pump with plastic impeller = M96
sam c. is offline   Reply With Quote
