Thread: Alarm issues!
Old 03-16-2013, 05:40 AM   #1
2003S
2003S's Avatar
Originally Posted by srad34 View Post
Hi all,
Does anyone know if you can disable the alarm system on the 986?
Any thoughts of if it can be disconnected?
I was in the same position -- I primarily use a non-remote enabled key, and the 10 second delay before the alarm sounds is annoying (BTW, if you just put the key in and turn it to the Accessory position, the alarm won't sound)
Regardless, I just disconnected the alarm HORN -- the lights still flash, but it is FAR less annoying -- plus, living in the city, car alarms are just annoying -- no one actually pays any attention to them - IMO, they are completely worthless. Now if they armed an auto-taser, that would be different :-)
But I digress -- If you want to disconnect the alarm horn (which is separate from the main horn) open the frunk, remove the cowl that covers the battery, and the alarm horn is to the right of the battery (facing the windshield from the front bumper). It is easy to disconnect -- just one connector to remove. It's a very easy job.
[edit] -- here's a picture from another thread:
http://986forum.com/forums/general-discussions/36595-boxster-s-alarm-keeps-going-off.html
2003 Midnight Blue S
LN IMS Retrofit
