I think you have pulled the vacum hose off the resonance flap actuator. If you follow the schematic line from 29 it should take you to vacum diaphragm of the actuator. As I recall this is on the underside of the resonance tube you removed.
It's really tight in there and you might have pull the tube back out to get the vacum line back on.
I would imagine some of the codes you listed are from your resonance flap not actuating.
986 00S
