Old 03-13-2013, 07:09 AM   #13
seningen
seningen's Avatar
Here is what it looks like now. Not sure IF the press fit portion of the bearing is properly in place.
Is this the NORMAL amount of stud showing?
I can't tell you if that is in correctly or not -- specifically depth wise.
Several years ago I know while my mech and I were installing a LNE kit
we (probably me :-) got it a tad cockeyed. and it would not insert completely.
Tight access had me strike it at little off kilter.
We fashioned up a puller with a piece that would fit the LNE bolt.
It came out easily and we were able to reinstall with no issues.
I'm sure a machine shop could fashion you up such a piece if
you have the specs of the LNE bolt and the bolt on the end of the puller.
Note this is the original extraction/insertion tool -- I believe the methods
have changed. My mechanic was one of the early indy's to perform the service.
So I don't know if the newer tools are the same or not.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline
