Old 03-13-2013, 06:48 AM   #10
coreseller
I know you're upset but I doubt the car is junk. I suggest you walk away from the situation for awhile and settle down and reassess, it will get worked out eventually. For some reason or another I remember Jake posting something years back about a method to remove the outer bearing race using a puller of sorts, think of an inverted gear puller with the teeth pointing outward. Don't worry Homeboy, it will get worked out.
coreseller is offline
