Also, to be as accurate as possible on mine, I'm currently in the process of swapping out the clutch, flywheel, IMS bearing, water pump, plugs, pulleys, and aos, which I'm pretty positive are all original at 100k miles. I also had to replace the passenger door panel as the top of the one that was in it was sun damaged. However, the PO included a brand new panel in the sale along with a few odds and ends and a rear speaker kit. All and all, not a bad deal.
