So here's my final parts list... This should allow me to replace both inner CVs, new boots on the outer, replace the bolts, and new axel nuts... Hopefully I have everything I could possibly need?
999-084-641-01-M100 Quantity 2
Wheel Hub Nut 22 X 1.5 mm, Rear Left/Right (2 per car, sold individually), Boxster/Boxster S (1997-04), Each Brand: Genuine Porsche
900-067-123-02-M260 Quantity 12
CV Joint Bolt, 10 X 50mm (6 per joint), Manual, Rear - Boxster S (2001-02), Each Brand: OEM
911-332-030-01-M60 Quantity 2
CV Joint, Inner Rear, Boxster S (2000-04), As Needed, Each Brand: GKN Loebro
911-332-257-00-M395 Quantity 2
Axle Boot Clamp (73 mm), Boxster (1997-02), Boxster S (2000-04) Rear Inner/Outer (4 per car, sold individually) Brand: Oetiker
928-332-257-01-M395 Quantity 2
Axle Boot Clamp (34 mm), Boxster (1997-02), Boxster S (2000-04) Rear Inner/Outer (4 per car, sold individually) Brand: Oetiker
SWE-101
Swepco CV Joint Grease, enough for four joints, 14.4 oz
928-332-293-02-M60 Quantity 2
Axle Boot, Boxster/Boxster S (1997-02) Rear Inner/Outer (4 per car, sold individually), Boxster S Tiptronic (2003-04) Rear Inner/Outer (4 per car, sold individually), Boxster S with Manual Trans (2003-04) Rear Outer (2 per car, sold individually) Brand: GKN Loebro
996-113-113-00-M30 Quantity 2
Gasket, Exhaust Manifold to Catalytic Converter (2 per car, sold individually) Boxster/Boxster S (1999-04), Each Brand: Elring Klinger
996-111-107-55-M17 Quantity 2
Gasket, Exhaust Manifold to Head (2 per car, sold individually) Boxster/Boxster S (1997-04), Each Brand: Victor Reinz
