Old 03-11-2013, 03:14 PM   #15
MFozz
Originally Posted by Mike o View Post
Take the axles off. Replace CV boots, boot clamps and joint lock rings. No need to replace bolts. Maybe order a couple just in case! Make sure to re-pack cv joints with axle grease as recommended. You will need new axle nuts too! Follow the instructions on pelican.
You don't think it's necessary to replace the bolts? This is something I wasn't sure of either, so I figured I might as well er on the cautious side and replace them.
MFozz is offline   Reply With Quote
