			Here is some info that I could quickly find:
 "You were correct in checking all the fuses first. Generally speaking should it be a fuse you will lose your gauges as well. The most common problem with the loss of the LCD display for the odometer and other functions in that panel is a bulb. To access it you must remove the cluster. Once removed it is located directly in back of the LCD and is a 1.5W 12V.
 Scott Slauson - PCA WebSite - 3/29/2004"
