Old 03-10-2013, 08:32 PM   #2
Chuck W.
Chuck W.'s Avatar
Originally Posted by ChrisZang View Post
Kevin,
just to add one tiny little detail:
The cluster which you reprogrammed was an -> MY 01 cluster made by Motometer.
The 01 -> clusters were made by VDO
And even though they look very similar from the outside they are 100% different on the inside. So I doubt that an EPROM reprogramming which worked on your cluster can simply be applied to a VDO cluster
I had no idea, thanks for the heads up. So, an '03 may not work. In that case I'll look into doing a 996 cluster install.
http://www.pelicanparts.com/techarticles/Boxster_Tech/90-ELEC-996_Cluster/90-ELEC-996_Cluster.htm
1995 Porsche C4 Cab
