Old 03-10-2013, 06:19 PM   #12
AKnowles
AKnowles's Avatar
thstone is dead on. But keep in mind that this car also has a hesitation that kicks in sometimes when the car is warm. If it hits you and you are not used to it the car will stall if you continue to let out the clutch. The solution is simple. Either give it a blip of gas to compensate or just hold the clutch where it is for a half second then continue.
Of course if I cleaned my MAF maybe I and others would not have this issue. But I've seen quite a few comments on it.
