Old 03-09-2013, 06:45 PM   #1
3.2S
I checked the bearing as you mentioned with the crank and cam locked. There is no play in the bearing and I took the seal off to inspect, smell, etc. I'm pretty sure it's a double row bearing that's why I'm considering leaving it in. The thing is there's already oil in it (I assume it had grease when new). I'm going to quite pondering it and just change it as you suggested.
3.2S is offline   Reply With Quote
