Thread: Engine Rebuild
Old 03-09-2013, 07:14 AM   #2
pjq
[QUOTE=Jake Raby;330736]Anything is balanced if your tolerance of acceptance is wide enough. These engines are dynamically balanced very poorly from the factory; they just installed a 37 pound dual mass flywheel to smooth it out. The accountants said it was cheaper that way.
Jake, I always enjoy your sarcastic comments!! haaaaa!
So, how is the balancing of these engines carried out, are weights added or shims used? I understand the precession of placing things back where they came from with the allowable tolerances but what actually is being balanced the crankshaft, pistons, camshafts??
