				2000 Cluster - Silver Gauge Faces and Trim Rings
			Sold - Thanks for Looking
Are you tired of staring at a plain set of black gauges in your Boxster?  Consider upgrading to a set of silver gauges with aluminum trim rings.
This cluster works, but the lcd for the clock/oil gauge is marred.  I think the best use for  this cluster would be to remove the gauges and attach them to your circuit board.  (The gauge cluster comes apart in two pieces.)  This is much easier than removing the needles and attaching aftermarket gauge faces.  If you are in the Richmond, VA area, I'll help you do the work.
The cluster is from a 2000 non-S and should be compatible with all 1997-2000 Boxsters.  I do not know if it will work on 2001 and later cars, but feel free to give it a try.
Asking $150 or best reasonable offer. Send me a PM if you are interested.
				__________________2000 Arctic Silver/Black, Hard Top, On Board Computer
						Reason: Item Sold
