Old 03-05-2013, 03:40 PM   #10
chaudanova
Originally Posted by TheProspector View Post
If you mean the little round "nubs" on the seatbelt that keep the buckle from falling down when not in use, then yes.
I just ordered 2 from the same place as I got the belt material. Each consist of 2 halves: one that has a hollow middle and the other with a sharp spike. I measured up on my old belts from the bottom of the nylon to the original stop. This measurement was approx 24". They install by pushing the spiked half through the nylon (I pushed mine all the way through with the help of a flathead screwdriver.) Then push the other half onto the spike. It will hold in place. I cut off the sharp excess protruding and used adjustable pliers to clamp down and ensure they were seated all the way. Then used a lighter to melt and smooth the cut spike.
They are a little larger than the original buckle stops, but not a big deal.
Let me know if you'd like a close up of anything.
Thank you very much for the explanation. I appreciate it! Yes, if you get the chance, could you please post a close up picture of the new installed/uninstalled buckle stops?
Thanks in advance!
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
