Old 03-05-2013, 02:59 PM   #1
AKnowles
AKnowles's Avatar
Well if you do manage to split them without damage, you might want to consider some additional tools. After just completing the headlight restoration on my new litronic lights I can tell you the pneumatic orbital sander is a must to remove significant amounts of material. You can puy the foam backed sander pads from mequires in 100 & 3000 grit from Auto Detailing Solutions -- Meguiar's Car Wax, Auto Polish & Detailing Supplies Store that will do the job. If you have a harbor freight around you can get a Chicago orbital sander or other model plus a air compressor. But buy one larger than I did. The 3 gallon one is suitable for paint (what I really bought it for) but doesn't have a large enough capacity and compressor to keep up with the tool.
I wet sanded the exterior and did remove material. You'll need to do the same to get rid of the burn if it is just on the surface. Too deep and I think you can forget it.
