Old 03-05-2013, 12:45 PM   #10
Skrapmot
Skrapmot's Avatar
P1128 & P1130 Fault codes advice
I've had the same error codes come up on my '98. cleaning the MAF is what did the trick.
Buy some MAF cleaner spray, and search Pelican Parts on how to pull it out and what tools you need. The spray and torx driver will set you back $10 and about 30-45 min of your time. It's an easy fix and easy to get to. While you're in there you can check your air filter and pull out any debris from the air box (I found 2 cigarette butts!).
