In regards to replacing a window regulator because the window does not come down far enough, the regulator is not necessairly the problem. I replaced mine and still had the same problem. The microswitches were all good and it turns out to be a simple adjustment for the window clearance height done by removing the rubber plugs under the bottom of the door and adjusting (clockwise many turns) the E-6 Torx screws for the window channel.
