Old 03-02-2013, 08:05 AM   #1
Auf los!
Auf los!'s Avatar
Thanks, Johnny, I was hoping you would chime in.
By "aggressive" in the rear, you mean the tires will be out to the edges of the fender, but will not "stick out," correct? I'm not a fan of the "Hot Wheels" look!
And to bring the front offset down to about 45, I would fit a 5 or 6mm spacer, correct? This will widen the front track, right? Are you suggesting this for suspension geometry reasons, tire clearance reasons, purely to have the tire/fender look match the rears, or...?
Thanks for your help!
Auf los! is offline   Reply With Quote
