					Originally Posted by marymarcs  I wanted both LED cluster to turn on my new Depo LED Tail lights.  I rewired the pin on the car so that the fog lights are wired in parallel.  When I plugged in the lights I still only had one LED cluster that would light up.  The fix was to add a 50W 1 ohm resistor in parallel with one of the tail lights.  Now both LED cluster on both tail lights come on when I apply the brake.  I hope this helps!  |
Where did you get the LED center brake light?
my Depos just arrived.  Can't have mismatching lights!!
