Old 02-26-2013, 09:03 AM   #15
BYprodriver
BYprodriver's Avatar
Originally Posted by pjq View Post
Bypro, ok that was what I was thinking but what about the block? How can I check if the bearing turned/spun in the race of the block?
Once the support bolt/axle breaks the IMS just bounces around. There is no way to know how much damage was caused without inspecting every surface inside the engine. You can get a sneek peak by removing the oilpump housing behind the front engine mount & inspect the 2 gears inside to see if the metal grit got through the pump.
