Old 02-26-2013, 03:30 AM   #10
Lobo1186
Originally Posted by Ckrikos View Post
My starter has started to make noise upon startup. It sounds like a belt is slipping when the car fires up. You only hear it when the car hasn't been started in a while. I'm having some major service done inif a month and I will probably have it replaced. I was just wondering how much more lifif it almoste does my starter probably still have if I don't replace it.
If it sounds like a short grind right after the engine starts, I believe it is the "bendix" shaft (correct the name if wrong) anyway its somewhat common that over time it doesn't retract fast enough after cranking the engine so it grinds. You can start by greasing it if you do not want to replace the whole unit.
