Old 02-25-2013, 07:44 AM   #3
cbracer
I am watching this thread too, the microswitch on my passenger door thinks that the door is closed all the time and so I have to manually roll the window down a little bit so it will clear the door seals. I will be taking the door panel off soon to take a look, and so I might run into the same issue.
When you pull on the handle a slight amount, but not enough to unlock the door, does the window drop? If not then you might have a microswitch on the handle gone bad which can be replaced. Those switches cause the window to drop, and the one in the door lock mechanism holds the window down when you release the handle because it senses the door is open.
hope that helps
cbracer is offline   Reply With Quote
