Old 02-24-2013, 04:45 AM   #1
Sunsport
Sunsport's Avatar
Originally Posted by pjq View Post
2nd owner, 2004 Boxster S, 40000 miles, Mobil1 0-W40 just changed approx. 6-7 hrs before failure. oil changed every 7 - 8000miles.
start up shiftting 1st - 2nd approx 2300 RPM then when engine up to temp. shiftting 3200 - 3500RPM unless I want to pass!
Engine shut down on her own, then when stopped I restarted, she stated immediately, that was my introduction to the "death rattle". Not knowing the problem I restarted the engine, briefly, two more times after this.
Well, the fact that is started fine after is a good sign - if valves were bent it would have run poorly. Hopefully it's a simple bearing replacement and then back on the road for the nicer weather.
Good to see another Eastern Canadian on here as well!
Sunsport is offline   Reply With Quote
