Old 02-22-2013, 08:39 PM   #20
trygve
Originally Posted by 986FortyEight View Post
A good example is the one wire (looks like ground) that travels under the emergency brake and dives under the center tunnel through a rubber grommet. My guess is: ground to the fuel filter, and should probably keep that to be safe. The pix of most SPB builds out there show no wire there. Thoughts?
You are correct, it's the ground wire for the fuel filter. I think Brad told me it's not necessary. And you'd think it would be possible to ground it under the car somewhere also. I just fed it cleanly to the nearby ground pin on the passenger floor pan (which on my car was never used for anything, unlike the driver side) so it doesn't get in the way of stuff on the driver side floor like the rails or belts.
I only have 1 cable running along the center tunnel now, and that's the thick cable that goes to the engine (probably the battery cable going to the starter?). Everything else that used to go down the tunnel channel is gone -- parking brake lever sensor, window & heated seat switches, oddments tray alarm sensor, ashtray light, etc., all gone.
trygve is offline   Reply With Quote
