Old 02-21-2013, 05:49 PM   #7
mikefocke
As thstone said, just drive it a while. The ECU is forced into using a set of predetermined values and will gradually get smarter and do a better job of balancing air and gas. Don't change anything until you are sure, having driven under varying conditions for several days and 100+ miles that the ECU didn't fix the issue. Most MAF diagnosis are wrong and it is an expensive part.
