Old 12-24-2005, 06:01 PM   #3
mjw930
You will probably need those 5mm spacers on the rear but in that size they will probably not have a hub centric extension since the wheel should still be able to engage enough of the centering hub already on the spindle to work correctly. You will need longer lug nuts.
mjw930 is offline   Reply With Quote
