I did it on my 03S, works great, takes about 15 minutes. The key is getting the right wires, there's a WV part number you can order online, they're about $3 each and you need two. They are slecial because the connector on the end fits into the harness behins the instrument cluster.
So, two wires cut in half gives you four connectors, you take out the console, stick them in the approriate slots and extend the wires to the dash area. That gives you the ability to control all of the OBC functions via four momentary switches, two dash switched or the stalk. I also saw one install where someone put a Tiptronic wheel on a standard car and used the shifter buttons to control the OBC.
Chris.
