Old 02-16-2013, 08:29 AM   #20
shadrach74
Idling with 5PSI oil pressure and 290 degree oil for 170 hours killed the rest of the engine, but didn't hurt the IMS Solution. This just barely touches the surface of what seven generations of IMSS development have entailed. This wasn't developed overnight, or with anything less than an open checkbook.
Hi jake,
A few questions:
1) why would an idling engine "fry" at 5 psi and 290df?
2) Why would an idling engine have an oil temp in excess of 290df?
I understand that 5psi and 290df is sub optimal, but these parameters theoretically provide better lubrication then the engine gets for the first 10 minutes of running after start up on a cold morning.
Also, why would your bearing survive while the rest "fry"? I understand the crank is under a different load than the IMS, but the crank has more than triple the number of bearings to carry that load.
While I've never rebuilt a Pcar engine, I've rebuilt the engines of a few others, both air and water cooled. I've also spent a lot of time chasing cooling issues on air cooled engines. My experience monitoring engine parameters tells me that its that there is more to this story. I don't see why an idling engine with the cooling system functioning properly would ever see oil temps of 290. That's auto crossing on a hot day oil temp, not ticking over at 600 rpm oil temp...
shadrach74 is offline   Reply With Quote
