Old 02-15-2013, 06:03 PM   #7
AKnowles
AKnowles's Avatar
A couple of thoughts for you:
1) To test the cluch just drive along casually at 35 mph in third gear. Then change to fifth and stamp on the gas pedal. If the RPMs surge your clutch needs repair. If the car begins to gradually speed up, it is in fine shape (mechanical clutch parts).
2) All - that I have seen - hydralic clutches have a master and slave hydralic cylinders. Check yours for wear and tear (i.e. bad seals/leaks). If you do not see any, good sign. Ours are non-adjustable, which means you can bleed the system to remove any air bubbles. This will sometimes improve the feel - be less mushy, but cannot adjust the point of clutch engagement.
If your master or slave units are worn, you can often rebuild them (I have not checked for a rebuild kit so am unsure if the Boxster parts are available) or just replace them. Usually not a difficult job since you don't have to split the engine/transmission to replace these components.
