Old 02-14-2013, 01:36 PM   #29
The Radium King
The Radium King's Avatar
have the shop give you the old water pump and give it a good look. if the plastic impellers on the pump are missing any chunks (from a bad bearing in the pump allowing the impeller to smack against internal engine walls) then these pieces are throughout your engine and will need to be cleaned out lest they block important coolant passages.
