					Originally Posted by tcallas  Thstone,
 I do not have my Excellence article directly in front of me for reference, but I believe I was speaking about the M97 engine with the larger diameter IMS bearing.  As for the M97 engine, its IMS bearing cannot be replaced without complete dis-assembly of the engine, having said that, I feel that removing the outer seal of the IMS bearing is the best thing that one could do to temporarily lengthen its life, so AT LEAST it can get splash lubrication. We have removed the outer seal on many M97 IMS bearings, on automobiles with mileage well below 30k miles and all have had substantial engine oil contamination.
 Yes, I do recommend switching to a boutique type of engine oil, instead of Mobil-1, because I feel that elevated levels of ZDDP is critical to most any engines health.
 Tony Callas
 Callas Rennsport
Tony,
What do you use to pull the seal off the bearing? I have replaced an IMS bearing on the M96 and understand securing the crank, cams, chains, and shaft, but what do you use to reach-in and grab the outer seal on the M97 bearing?
Thanks Much
