Old 02-12-2013, 06:55 PM   #15
AKnowles
AKnowles's Avatar
Ok mine is installed. Helped that my lid was already off do to a broken hinge. Mine has a small wrinkle when installed. Wife said it was there to start but I'm not so sure. I think my drivers side center console cover plate may be the issue. I also used a dremel to clean up the broken hinge area. And still fitting the rear plate was tough. I cut off the ears on the plate but I don't think that is the issue. Just a tight fit. Might be same issue with the wrinkle.
As I plan to pull the center console again soon I'll have an opportunity to review it from underneath and readjust. It's too dark for picks but will grab some tomorrow to illustrate issue. Install takes about an hour.
