Old 02-12-2013, 11:39 AM   #12
Jake Raby
Engine Surgeon
The band aid comment cannot be too comforting to all of those who have had LN Engineering bearings installed either at Jake's shop, independent shops or DIY.
You are making something from nothing.. Anyone who we have installed a bearing kit for that wishes to apply an IMS Solution gets the full cost of the IMS Retrofit bearing (limited to the retrofit kit) knocked off the cost of their IMS Solution procedure, if we carry it out here. Of course, the only people who know that are those who are our customers already.
What I was referring to as a band aid was adding a device or a modification in lieu of proactive bearing replacements.
That means that even my IMS Guardian system is a band-aid. At least it is a non-invasive band aid that offers a symptom before failure and for a nominal cost when carried out as DIY..
The only way to avoid the common collateral damages related to ball bearing IMSB failure is to eliminate the ball bearing that creates the collateral and secondary damage.
US Patent 8,992,089 &
US Patent 9,416,697
