For this who have fixed the knotchy shifter
Just curious what did you do to fix it? I've read many times remedies of replacing Transmition mounts, motor mounts, fluid change, etc. I've changed the tranny fluid with swepco. Problem has worsened. While warming the car up in the driveway. I'll depress the clutch and run through the gears smoothly. But as soon as tires roll, forward or reverse, the shifter gets very knotchly, almost stubborn. I can hear a loud click from outside the car as I shift from 1st to 2nd. Interesting, when the car is run for over a 1/2 hours things are much smoother again. I liked to hear any success stories and tips regarding what I should look at.
Thank you
