Old 02-11-2013, 08:54 PM   #3
Kenny Boxster
Moderator
It may just be a regular screw that holds the transmission. It's certainly not the transmission drain plug or where you fill the fluid in the transmission. When you say you have an oil leak, is it engine oil? That could indicate a leaking RMS or loose oil drain plug.
