Old 02-09-2013, 11:29 AM   #36
thom4782
thom4782's Avatar
+1 on JFP advice. Inspect the oil filter for debris before removing the transmission.
If this happened immediately after the major service, I would ask to be present as the dealer begins to inspect the car. It's possible that the dealer did something wrong during the major service that led to the problem. There are many reasons the engine could fail catastrophically. Some could be because a part failed in the engine (IMS, chain ramp, etc.) Others could be due to improper service (not putting enough in oil in after an oil change, etc.).
PS: It's possible that the IMS could fail in the blink of an eye. That said, the IMS Guardian provides an early warning by detecting metal debris in the oil sump before the bearing becomes so unstable that the timing chain jumps a sprocket tooth or two. If the dealer changed the oil and did not see debris in the oil filter, then it would be a shocking coincidence to me at least if the IMS failed just a few miles down the road after leaving the dealership.
