Old 02-09-2013, 09:45 AM   #1
drbodzin
San Diego Boxster
drbodzin's Avatar
Did you block sand down to the original white primer or is the white from primer that you applied? Also, what grit paper did you use to block sand? Thanks.
The whole car has been block sanded and the primer was used to find high/low spots. It was not sanded down to metal or the original primer. The work is being done by Brad Diez at Speed Zone Paint & Body in Santee, CA.
drbodzin is offline   Reply With Quote
