As you can see, Lexol is pretty high on themselves also!
LEXOL LEATHER CONDITIONER AND PRESERVATIVE
THE PRODUCT:
LEXOL is a liquid conditioner and preservative intended for use in the care and conservation of leather. Its purpose is to maintain the strength, beauty, utility and flexibility of leather - old and new - and to restore resiliency to old or neglected leather that has become hardened and stiff.
PRODUCT RATIONALE
In the manufacture of leather, as a final and essential step, the tanned hide is subjected to a process called ”fat-liquoring” in which it is treated with a generous supply of special oils - emulsions prepared from the appropriate lubricants - which lubricate the leather to confer the desired qualities of softness, flexibility and strength. Thus, when the leather leaves the tannery, it is at the correct pH and is fully lubricated due to the unique capability of these emulsions to be readily absorbed into, and combined with, the leather’s fibers. However, these oils must still be replenished periodically to maintain proper lubrication and to avert any tendency to deteriorate. The type of preparation that is most effective in achieving both these goals is an emulsion similar to those employed in the original manufacture of the leather. LEXOL is an emulsion of this type.
WHY LEXOL IS SUPERIOR TO OTHER LEATHER CONDITIONERS AND PRESERVATIVES
The oils in LEXOL have been modified to facilitate effective distribution of microscopically fine oil droplets which can be more readily absorbed into the leather fibers than the comparatively large droplets typical of raw oils or less fine emulsions. LEXOL’s smaller oil droplets combine with the fibers, because of their affinity or adherence that is lacking with other oils. Thus the modified oils in LEXOL are kept under control and are retained in the area of application. In this way, LEXOL is able to nourish the leather and its fibers while protecting against migration, or seepage, into adjacent materials or surfaces.
Many leather dressings utilize chemical solvents in order to facilitate penetration of oils into the leather. Such solvents can lead to ”bleeding” or migrating onto adjacent materials, causing discoloration or other damage. In addition, such chemical solvents may be flammable, irritating or toxic.
LEXOL does not contain any chemical solvents. As an aqueous emulsion, it achieves several objectives: (1) fiber penetration and nourishment; (2) absorption and retention in the leather; (3) control of migration or seepage. Unlike most organic solvents, LEXOL is nonflammable, odorless, non-toxic and non-sensitizing to the skin. Also, LEXOL does not impart a greasy or tacky feel to the surface of the leather.
Although LEXOL is widely accepted as a treatment for the more common vegetable and chrome-tanned leather, there are certain leathers for which it is not suitable (e.g., napped leathers, such as suede or glove soft leather, which call for treatment with lighter lubricants). NOTE: Leather that has become cracked from inadequate or inappropriate care cannot be restored to its original state by any available method.
In summary, LEXOL is readily absorbed into the fibers and provides lasting and effective lubrication without migration while leaving leather feeling soft and smooth.
